Headers
What I do to seafoam is put 1/3 of the can in the PCV, 1/3 in the oil, and 1/3 in the gas tank. I let it run for a bit to get the seafoam to sit, let it sit (1 hour minimum, overnight is best), run the car til it stops smoking, and then change the oil.
Welcome to the fun of headers! I had the same problem when I put my headers in. The EGR tube wasn't sitting right. I did use a prybay and slowly moved the header bracket away from the valve cover to give the EGR more room. Take the EGR off and let the car run to normal operating temp so the header is hot and easier to bend. Besides that, there is no other way unless you take the header off and use a machine to bend it.
oh and my cars a 1997, when we tried heating it up with an oxy acedaline torch and a pry bar to bend it, but yes we were both worried that it would break.
2fast4u
06-04-2007 08:34 PM
