government chip!!!!
Old Mar 16, 2008 | 08:29 PM
rcrd_deleon11's Avatar
Default government chip!!!!
does anyone know where i can locate the gov. chip and remove it from my 98 3.8L camaro
Old Mar 16, 2008 | 08:33 PM
Big_Bird_1985's Avatar
Default RE: government chip!!!!
I think you mean governor. If I'm right are you talking about the thing that keeps you car from going above 110 or some speed like that. If you are it isn't a chip it is programmed into your PCM. To remove it you have to buy a handheld tuner and get rid of it that way or take it to a dyno and get it dyno tuned. Hope this helps.
Old Mar 16, 2008 | 08:35 PM
02StanGT's Avatar
It's a governor. Not a chip. It's built into the PCM. You need a tune to remove it. Or you can take all the speed sensors off your car, and it will not be there... But you wouldn't be able to see whether or not you got past OMG 118 mph. Why in the world you need to go faster thanthat, is beyond me.
Old Mar 16, 2008 | 08:36 PM
thanks!!!! how much does the tuner cost?
Old Mar 16, 2008 | 08:38 PM
02StanGT's Avatar
More than it's worth. Most are about $400.
Old Mar 16, 2008 | 08:42 PM
ok....i really dont now much about the performance chips but would you happen to know where it would go if i was to get one???
Old Mar 16, 2008 | 08:49 PM
There is NO CHIP to go into that car if you were to get a handheld tuner I got mine online try froogle its google shopping it works. The tuner plugs in under the dash on the driver side if you stick your head under the steering wheel and look down on the right side its a "black little box" it goes there plug it in tune it then install tune unplug and that is it.
Old Mar 16, 2008 | 08:51 PM
what would the tuner improve???
Old Mar 16, 2008 | 09:14 PM
02StanGT's Avatar
Come to think of it, I don't think they make a programmer for your car. Only one I could thinkof was Hypertech, and they on make it for '00+ Camaro. To get a tune you need to either, go to a dyno shop, go to www.hptuners.com, www.pcmforless.com. Best bet, would be the last one I mentioned. Cheap and I've heard nothing but good about them.
Old Mar 17, 2008 | 03:11 PM
Chappie99's Avatar
Holy S#!t. Government Chip!!!!!!! Sorry. I almost fell off my chair.
