Got everything installed but still rides the same......
Wow, you give up easy. Next problem will be on the SS, and he'll say "This blows I'm selling this and picking up a 5th Gen SS".
I just got my front upper control arms, upper ball joints, lower ball joints and outter tie rods installed, a wheel alignment and my Maro still rides the same, the steering wheel is real hard when I turn and park and the steering wheel shakes when I go above 50. What is this?
Did you tell your mechainc the problems? With the amount of work they did they should have had no problem figuring out what was going on at no or little additional cost.
We used to have to all but beat information out of customes. Customers used to come in and say the car needs a tuneup. I would do the tune up and then the car would come back the next day and the owner would say "you didn't fix the car its still hard to start when its hot"
If you have uneven wear, feathering, etc then it will definitely ride different after alignment because you are riding on a different wear pattern on the tire.
