fuses
Old May 30, 2007 | 10:59 AM
buddywackos's Avatar
Default fuses
i checked the fuse relays under the hood today to find that the fuse for the air pump isn't there. i'm not having any problems out of the car, or since i've had it, so is that supposed to be there or not? some fuses just aren't supposed to be there, but i don't know if this is one of them.
Old May 30, 2007 | 11:47 AM
Default RE: fuses
Power to the pump is provided throughthe "Secondary Air Injection Pump"relay. Should be a 20 amp fuse controlling the relay and a fusible link providing power to the relay.
Old May 30, 2007 | 05:05 PM
usarmyrangrs's Avatar
Default RE: fuses
Hmm. I wasn't even aware that V6 models were equipped with an air pump.
Old May 30, 2007 | 07:11 PM
Default RE: fuses
Some 3.4's have it. Don't know about 3.8's.
Old May 30, 2007 | 08:53 PM
Default RE: fuses
That's probably why. I'm almost certain that all 3.8s do not have them.
Old May 31, 2007 | 10:10 AM
Default RE: fuses
alright. i was checking, i didn't know ifmy car had it or not.
Old Jun 2, 2007 | 10:12 AM
01 Camaro Cp's Avatar
Default RE: fuses
Check your emmissions lable under the hood. That will tell you for sure.
vnctvega
Jun 23, 2012 01:31 PM
gville4life
Mar 12, 2010 08:49 AM
bashgod
Nov 25, 2009 11:56 AM
luvmysccamaro
Feb 4, 2008 11:04 PM
smby101
Mar 11, 2007 06:47 PM
