Fuse Help
Old Apr 13, 2006 | 04:52 PM
jsviking08's Avatar
Default Fuse Help
I need to know what size fuse it is for the Coolant Fan. Thanks Josh
Old Apr 19, 2006 | 03:12 AM
Default RE: Fuse Help
There are two circuits involved:
1) Fan power is fed trough the closed contacts of the fan relay.
The hot side contact is connected to a 20 gauge fusible link and has power at all times. The other contact feeds the fan.
2) Relay coil power comes from the FAN fuse, 20 AMP, power only when key is on the ON position.
When ground is applied to the other side of the relay coil, the contacts close through and the fan gets power through the fusible link.
izayuhgawd
Nov 21, 2011 09:24 PM
masonhoban
May 8, 2010 05:57 PM
ladybridgeport
Apr 5, 2010 08:44 PM
masonhoban
Nov 27, 2009 08:38 PM
vinnydc1
Aug 24, 2007 08:31 PM
