Fuel presure problems
Old Mar 3, 2006 | 02:41 PM
3.4LUV's Avatar
Default Fuel presure problems
94 3.4 L v-6 engine in a Chevy Luv,
Currently I had to replace the fuelrail, due to a faulty pressure regulator, and now the car will not hold at idle it will start and then die after a few seconds, but if I hold the throttle open it struggles. Checked fuel pressure and it was around 18 psi (usally it was between 22-25psi), checked the fuel line and there is no return from the fuel outlet off of the fuel rail, but plenty for the inlet. Could this be a result of a faulty fuel pump, or from the fuel rail (or the pressure regulator on the fuel rail), I am lost right now and could use some extra help. Thanks
Old Mar 6, 2006 | 02:34 PM
3.4LUV's Avatar
Default RE: Fuel presure problems
Well, after robbing a fuel pump out of a 3.8L gas tank, and doing a simple swap the problem is no more. Checked the pressure off of the 3.8L pump and it hit well over 60psi, which compared to my dead pump is an improvement.
chili74
Mar 5, 2015 07:10 PM
marten
Sep 3, 2012 11:26 AM
GSLcustoms
Mar 22, 2011 10:47 AM
96ZLT1
Oct 24, 2010 10:27 PM
sebi1990
Sep 28, 2010 11:26 AM
