fuel pressure regulator
Old Jul 17, 2008 | 06:55 PM
typeomang's Avatar
Default fuel pressure regulator
I have posted on this before, my camaro will not start on the first key turn, I have to wait for the alarms to go off and then turn key back to off and then start. I have an SES light. I was told that the fuel pressure regulator is the problem, can it be just taken off or do I have to remove the entire fuel rail, as always thanks for the help.......SFC
Old Jul 17, 2008 | 11:41 PM
Default RE: fuel pressure regulator
First get the car scanned and fix the SES problem. You should do a fuel pump and regulator test, as what you describe appears to be that FI system is not retaining pressure when the engine is turned off. This could be due to a bad check valve in the fuel pump, a bad pessure regulator, one or more leaky injectors, or even an external fuel leak (fire danger).
Old Jul 18, 2008 | 11:56 AM
evilkal's Avatar
Sounds like the pump is in the process of going bad
Old Jul 18, 2008 | 05:40 PM
typeomang's Avatar
I do not smell any fuel, I had a scan at autozone, it showed bad cannister purge solenoid, I replaced it, it also show a bad fuel pressure reg.will this clear up the ses? I know it is not alot to go on, any thing can help thanks.......SFC
Old Jul 18, 2008 | 06:33 PM
Guest
Guest
Posts: n/a
The fuel pressure regulator has to be replaced entirely. My car did the same thing, ended up around 350$.
Old Jul 18, 2008 | 07:43 PM
typeomang's Avatar
this is a 50 dollar part on the fuel rail, if you have not done this or know how to do this please do not respond........SFC
royco95
Aug 2, 2015 10:25 AM
sebi1990
Mar 6, 2011 06:58 PM
Kendagenius
Aug 13, 2010 08:34 AM
chadillac4110
Sep 17, 2009 08:43 AM
HURSTLT1
Dec 26, 2005 11:18 PM
