fuel pressure
Old Mar 22, 2007 | 01:57 PM
jimidude87's Avatar
Default fuel pressure
hey guys i need to relieve my fuel pressure and im not really sure how...i looked in my repair manual but it was very vague.any help is greatly appreciated.thanks
Old Mar 22, 2007 | 04:48 PM
Default RE: fuel pressure
There is a shrader valve (like a tire valve)on the fuel rail. With the engine cold, not running, & key OFF,(don't want to start a fire) wrap a rag around the valve to catch the sparay, press on the valve and fuel will squirt out till there is no pressure. Why are you doing this?
Old Mar 22, 2007 | 05:18 PM
jimidude87's Avatar
i blew the head gasket and im goin through the book and it said that i had to relieve the fuel pressure
Old Mar 22, 2007 | 06:27 PM
Ok. Chances are the fuel pressure will be way down by the time you start working on it.
Old Mar 22, 2007 | 06:49 PM
jimidude87's Avatar
alright thanks for your help
Old Dec 10, 2008 | 10:20 AM
maguilar496's Avatar
i couldn't find the "shrader valve (like a tire valve)"on my 96 3.8 does mine have one.
i'm also thinking of changing my head gasket.
Old Dec 10, 2008 | 12:45 PM
02StanGT's Avatar
Try looking at the passenger side of the fuel rail towards the very front of the car. May have a cover on it, but there should be one there.
Old Dec 11, 2008 | 08:10 AM
RSSteve's Avatar
ORIGINAL: maguilar496
My advise to you is if you can't find the schrader valve on the fuel rail then don't even attempt a head gasket job lol unless you KNOW what your doing... in that case go ahead and do it.
Old Dec 11, 2008 | 08:42 AM
no if i can't find the scharader valve, i'll just pull the fuel pump fuse/relay and run the car till it dies. That's what i do to all my other cars.
Old Dec 11, 2008 | 09:08 AM
SpecterGT260's Avatar
Ninja Administrator
if you can find a fuel rail you can find the schrader. it will be at the xtreme end, or on its own stalk. it will not be rubber like a tire schrader, but instead will be hard plastic and will have (most likely) a black cap over it somewhat like on the tire valves.
