fog lights won't come on
Old 08-05-2010 | 12:04 PM
bowtieguy92's Avatar
Default fog lights won't come on
i don't know if my bulbs are dead or if there is a connection problem but when i tun on my fog lights switch the little orange indicator light comes on, but the fog lights don't, if its replacing the bulbs i can't figure out how to get the lights out to do so, if its not what would i have to do to fix it?
Old 08-05-2010 | 12:11 PM
BoricuaHec01's Avatar
You have to replace the bulbs. At first its tricky but you can do it. Put your arm all the way down and the bulb is underneath the fog light thing, all you have to do is twist to the right and pull down, becareful putting it back in with the new bulbs, I've broken a few doing so but you learn to master it.
Old 08-05-2010 | 12:48 PM
thanks mang, you have any idea what bulbs are needed for the fog lights, (while were at it do you know what the rest of the lights are)?
Old 08-05-2010 | 03:43 PM
The fog light bulbs are 881, you can get them on ebay, especially cool colors like artic white or blue or if you just want the stock ones, pick them up at autozone or pepboys. The rest of the bulbs are above, easy to replace. Headlight bulbs are 9006, turning signals are 3157, the side marker bulbs next to the turning signal bulbs are 194.
Old 08-06-2010 | 10:02 AM
jj350's Avatar
check your relay first, you can swap it with the abs relay to test if it works.
pojo1988
08-27-2017 09:35 PM
98Z28ImportSlayer
03-16-2012 09:07 AM
Bing
09-20-2010 08:09 AM
bodykits
07-01-2009 09:52 PM
91 RS
02-24-2007 11:14 PM
Quick Reply: fog lights won't come on
