Firewall/amp question
Im hooking up my amp and i bought the amp wiring kit the you hook up to your battery and run back to the amp. I was wondering how to get the wires through the firewall and where it is. I have a '94 3.4L.
Thanks
Thanks
![Icon Speaker1](https://camaroforums.com/forum/images/smilies/icon_speaker1.gif)
If you take out the ECM, there is a hole in the firewall behind it. You will need to remove the panel under the dash on passenger side as well. Just wrap the wire with some electrical tape to a metal hanger or stick.
Specialist, i got mine. What i personally did, is i took out the glove box, the plastic piece under that, and then the plastic piece that runs along the bottom passenger door. Once you do that, go under the hood and unscrew the computer on the top passenger side(you can leave the omputer connected, just move it over). If you look down where the computer is, you should see a ruber garmet, which goes to the inside of your car. If you want go inside the car and double check where it leads to. Then what i did is cut the rubber piece a little then took a close hanger and taped the wire to the hanger and shoved it through into the car.
thanks bro did that, but didnt have to take the computer out or the glove box, just went to the passenger side an looked up to the right and saw that rubber hole. whats stereo did u have? i got a 500watt amp, two 10 inch subs, and a capacitor.
There should be a hole in your firewall where the steering column is mine was very small and we had to drill it a bit to get the 4 gauge wire through.
I'm running a Pioneer deck w/ Kicker KS600 door speakers powered by a Kicker ZX 350W amp and 2 12" Almani L7's powered by 2 Dual's bridged into 1200 watts. I have pictures of my setup in the link in my sig if you are looking for ideas on how to place the amps.
In the process of getting a 1Fraud Cap and a SVR or Optima Gel battery because when I install the HID's it's going to be pulling to much power for the subs to stay at max power.
Thanks man. She's been a blast to mess with. I have a few small things to do to her still but, nothing soon.
