finally done w/ motor but have more issues
Old Feb 19, 2012 | 12:04 PM
hawkins183's Avatar
Default finally done w/ motor but have more issues
hey guys finaly got the motor done running great but drives like a** just wondering i have checked everything in the rear and made sure it was tight never been under a camaro before untill now so not sure what im looking for. so here it is im getting alot of side to side sway from the rear it is so bad when i go 60 or more it wants to throw you side to side i HAVE GREAT RESULTS FROM HERE SO HOPING SOMEONE HAS AN IDEA????
Old Feb 19, 2012 | 12:17 PM
BasicConcepts's Avatar
Technical User
check you panhard bar (its the bar that runs from the driver side body to the passenger side of the axle) if its bent it can make you axle ride funny also check your sway bars make sure the endlinks arnt broken or loose and check the sway bushings
Old Feb 19, 2012 | 12:21 PM
MKCoconuts's Avatar
Broken sway bar or end links, I'd think. I'd go under the rear near the axle and check over everything...bushings, springs, shocks, etc. and see what looks bad.
I mean you could just have so much power at 60mph that your rear end doesn't want to stay straight!
MKCoconuts's Avatar
Damn. BC beat me to it!
Old Feb 19, 2012 | 12:23 PM
Technical User
lol its cuz im sneaky
Old Feb 19, 2012 | 12:42 PM
MKCoconuts's Avatar
I knew I should have looked behind the couch first!
Old Feb 19, 2012 | 12:50 PM
hawkins183's Avatar
thanks guys il check it over again what would be a good rear end to change it to i would liketo go rear disk if i go through changing all the bushings id just assume to have a better rear end
Old Feb 19, 2012 | 12:52 PM
Technical User
a z28 rear it will bolt right in if i remember correctly the manual z has 373s
Old Feb 19, 2012 | 12:56 PM
hawkins183's Avatar
thanks bc what years can i use
Old Feb 19, 2012 | 01:35 PM
Technical User
any 4th gen but you need to make sure the abs is the same some have 1 unit for the rear and some have 1 for each tire im not exactly sure what years are what
