Engine runs on 5 cylinders only
Hi,
when starting the engine in the morning (still cold) it runs very unsmooth and I guess it runs on 5 cylinders only. Then after ~1 minute everything is back to normal...
Any ideas ? Is this a bad thing or will renewing spark plugs help ...
Yea me to, I was getting that all week... Then it always says my oil is low when I know it isn't, cause I had an change in it 3 weeks ago, I also check for leaks which was none.... think senors are just old & just need to be replace
The car has been checked completely just 2 month ago.
It is the 3.4l and just ran 112k miles!!
So what do u think might be the reason for one cylinder giving out or whatever it does ?
Try the easy stuff first -- replace plugs & wires, fuel filter (supposedly every 50,000 mi.), try some Lucas Upper Cylinder Lubricant and Fuel Injector Cleaner...
Hopefully you replace your oil on a regular basis and have no debris in your engine...
Get a repair manual for your year Camaro and check the troubleshooting section -- get the version with a CD-ROM for your computer (saw it at Pep Boys)...
ICE
07-31-2006 11:17 PM
ICE
07-31-2006 06:45 PM
