Engine(?) making an odd noise
at about the 1900-2100 rpm range my 3.8 5m is making a weird constant clicking noise until i get above or below 1900-2100ish rpms, and the accelerator pedal also feels kind of like notchy
The gas pedal is a simple cable/lever. It should feel just about the same engine engine on or engine off. Most likely has nothing to do with noise. Do you have the clicking if you just rev the motor not in gear or when your driving or both? Is it louder going up hill or if you drive faster?
the sound stays the same volume no matter the speed, and there are no hills around me for miles and miles. and i havent revved in neutral to check but i will go do that
ok so its not just in that rpm range and its more of like a deep vibrating clunk in the engine that just gets worse after it hits 2000 rpm and only happens when the engine is warmed up
Can you do a video? it is starting to sould like a rod bearing to me.
I agree with Gorn. My engine did the same thing to me and I knew it was the rod bearing after driving the car a 1/4 mile or so with no oil. New engine later no isues.
Massey |
i can try to find a video camera, should i do the video like inside the carr?
Set it up to see the RPM gauge and then do one with it propped up by the motor so we can get a better idea of what the noise sounds like for better determination of your issue.
Originally Posted by Dappled Apple
(Post 449330)
well my car has stopped making the noise now, altho a different problem has shown up. when i go into 3rd gear itll stay at 1000rpm no matter the speed im going, the car will go faster but it wont rev up, get louder, and its not lugging down its like idling. but it doesnt happen everytime. i think were just gonna take it to a legit shop
