Door locks will not work but now the car starts.
I had a problem with the 98 camaro not firing once in a while due to no power to the engine control fuse. Now the car starts every time but none of the elect. door locks work including the remotes and the door switches. Also now there is a clicking sound from behind the glove box like a relay trying to close. Howare the 15 amp engine control fuse and other 15 amp fuses connected to the powerdoor locksand what could cause one to work when the other is not working? If a ground problem where to I check that?
