does anyone have a 3.4 rear turbo thread
Old Jan 31, 2011 | 09:30 AM
joseph_zlnsk's Avatar
Default does anyone have a 3.4 rear turbo thread
I have a 3.4 and I'm interested in putting a rear turbo in it. I basically want some ideas, I just want to see if anyone else has done this. Pics or video would be much appteciated. And no I don't want a v8 I'm fine with a turbo.
Old Jan 31, 2011 | 10:02 AM
Buffalo02Z28's Avatar
Who would want a turbo 3.4 liter?
Old Jan 31, 2011 | 10:50 AM
BasicConcepts's Avatar
Technical User
i wanted to...
no no one has a thread about it your car wont handle a turbo it may run for 10 seconds afterwords theres alot of things that need to be done
go to the search and type in "3.4 - 3.5 upper end swap" and read that thread its everything i found about getting your engine ready for forced induction
Old Jan 31, 2011 | 01:10 PM
Massey's Avatar
The stock heads and intake are so restrictive on the 3.4L that even putting a turbo on will not help much. This engine is not the best starting point for forced induction. DO what BC said above, that is your best chance for success
Massey
Old Jan 31, 2011 | 05:34 PM
I've seen a video on you tube advertising forced fed fabrication turboing a 3.4 and I am only looking for a few pounds of boost and something that is DIFFERENT. When I say a few I mean like 3 pounds of boost. I am not interested in a supercharger or doing a v8 swap. And I don't want a front mount turbo I want a rear mounted turbo. I can do it all it ain't my first rodeo. I just wanted to see how many others have done this and gather some ideas from it.
Old Jan 31, 2011 | 06:08 PM
And as far as the heads go would a good port and polish or head job on the 3.4 heads not be good enough special with only running about 3 psi?
Old Jan 31, 2011 | 06:12 PM
Don't spend time and money on the 3.4 cylinder heads. If you must have more power out of this motor, go with what Basic said and do the 3.5 top end swap.
Old Jan 31, 2011 | 06:33 PM
I searched and don't see any info on doing a 3.5 top swap. Only thing is found is basically were bc said he was going to do it and then his car is totaled
Old Jan 31, 2011 | 07:28 PM
mrfreez's Avatar
You'll need one of these:
http://www.vortechsuperchargers.com/product.php?p=4
Then you'll need a bypass valve and an intercooler.
You'll need to rebuild the engine from the main bearing up! Camshaft, heads, rods, pistons. Might as well do the 3.5L engine swap. Don't forget to swap the rear-end for a posi otherwise you'll just spin the tires with no traction and make alot of noise. You'll need to strengthen your suspension too with better sway bars, sway bar links, bushings, springs and shocks.
$10,000.00 and a week's work and your V6 3.4L will be able to keep up with a N/A LT1.
Old Jan 31, 2011 | 07:31 PM
Just buy an LS1 or LT1 Camaro. A $10,000 turbo is totally not worth it if its put on the 3.4 liter V6.
