Does any one know the stock pushrod length?
Old Sep 20, 2009 | 01:41 PM
If you are using stock heads, same ratio rockers, and stock cam, then the stock push rods will work OK, as the hydraulic lifters will pump up to get the push rods to the proper position. However, if you made changes, especially if you installed a reground cam, you will need longer push rods to make up for the smaller base circle of the cam, and use the procedure described by craby to get the proper length.
Old Sep 20, 2009 | 09:42 PM
3.4_V6_Maroboy's Avatar
SO should I get the cam out of the 3400 too?
95redcam
Oct 7, 2010 10:43 AM
ScottD
Dec 9, 2009 10:34 PM
92lxsleeper
Aug 26, 2008 10:40 AM
hotrodguy1986
Nov 13, 2006 02:12 AM
gotalcoholmanup
Jun 28, 2006 02:29 AM
