Crappy Start
Old Jul 25, 2009 | 06:39 PM
swier629's Avatar
Default Crappy Start
i have a 95 3.4 camaro. Recently i got an oil change and tune up, but the car still starts like **** usually take 2 or 3 turns for it to start. Any help, so it will fire right up? Someone told me maybe the EGR Valve. If thats it can i buy this at the local auto zone? Thanks
Old Jul 25, 2009 | 08:31 PM
It may be that the FI system is not holding pressure when the engine is off. could be due to a bad fuel pump (bad check valve), bad regulator, or a leaky injector. Try turning the key ON & OFF several times before turning it to the START position. If the car then starts right up you found the problem, and now you need to find the bad part.
Old Jul 25, 2009 | 09:48 PM
libertyforall1776's Avatar
Also define "tune up" -- I assume you change plugs/wires?
More than likely, like Pete says, it's a fuel pump going weak.
Old Jul 27, 2009 | 09:14 PM
swier629's Avatar
thanks guys ill check into that
GMDCAMARO
Dec 22, 2007 02:52 PM
sl1foru
Nov 16, 2007 12:33 AM
daltons 1980
Sep 16, 2007 12:59 PM
F88Berlinetta
Oct 3, 2006 04:30 PM
