Crankwalk?
Old Mar 11, 2007 | 01:22 AM
Kardon507's Avatar
Default Crankwalk?
Can someone please tell me what crankwalk is????Thanks
Old Mar 11, 2007 | 01:39 AM
coprunr's Avatar
Default RE: Crankwalk?
crank walk is excesive lateral movement in the crankshaft (front to rear) , usually occurs when the thrust bearing is worn or the thrust surface on the crank is worn or damaged
Old Mar 24, 2007 | 03:44 PM
Kardon507's Avatar
how much is it to fix that problem???????
Old Mar 24, 2007 | 03:56 PM
Depend if it is just a bad bearing or a bad crank.
