crankshaft interchange
Old Apr 21, 2010 | 09:53 AM
ed1380's Avatar
Default crankshaft interchange
spun a rod bearing and am looking for a crank. It seems alot of chevy 3.8 v6 are the same l36 engine. Would they have the same crankshaft?
Also where could i find one?
Thanks
Old Apr 21, 2010 | 05:15 PM
Good question. I checked with Rockauto.com and they list a reman Crank. I am not sure if this link will work. When you pick on the part number to see what else it fits you get a list of just about every car that had a 3.8 from 95 thru 07. I would guess that would mean even the seires III 3.8's had the same cranks.
While I think the crank is unchanged all those years it is possible there is some feature that needs to be there for some years but does not hurt being there for the other years. Meaning GM my have 4 different part number that cover all those years but this suppier figured out a way to make a crank that will fit any of the years. So it is not 100% that a crank from a 95 will go right into an 07. Hopfully Someone like MusicMan will chime in
http://www.rockauto.com/catalog/rafr...&parttype=5292
Old Apr 21, 2010 | 07:04 PM
MusicMan's Avatar
The Jazz Man
All L36 (series 2) and L26 (series 3 3.8) are the same, fwd or rwd.
Old May 17, 2010 | 10:51 AM
ed1380's Avatar
thanks ended getting one from ebay
Old May 17, 2010 | 11:46 AM
ed1380's Avatar
BTW anyone know where I can get a stock camshaft
charlie94
Oct 28, 2011 08:43 PM
1989_RALLYSPORT
May 31, 2011 07:14 PM
typappy
Sep 18, 2009 07:03 PM
bigacuralvr
Jul 7, 2009 03:47 PM
kreaton
Jul 8, 2008 11:22 AM
