Cooling Problem / Help Getting to Thermostat
Old Oct 21, 2007 | 11:38 AM
cyclesofnothing's Avatar
Default Cooling Problem / Help Getting to Thermostat
I have a 95 with a 3.4 V6. My cars temperature seems to be going erratic once it heats up. When the temperature rises higher than normal the heater blows no hot air out. Then the temp will go back down to normal and the heat will start coming out of the vents again. It does this back and forth while I'm driving. I'm not too familiar with cooling problems so I'm guessing it is probably the Thermostat. Please let me know if I may be wrong or if any other suggestions. Now, when I go to try to take the thermostat housing off, it seems almost impossible to get to the right bolt as there is too many things in the way. I've tried using attatchments on the wrench and the u-joint attatchment but have had no luck. Has anyone here removed the housing? If so, can you please describe the method you used? Or if anyone else has suggestions to what other tools I may be able to use to get to it. Any help much appreciated.
Old Oct 21, 2007 | 06:55 PM
CamaroKid16's Avatar
Default RE: Cooling Problem / Help Getting to Thermostat
hey, to be honest, just take it to jiggy lube or w/e and have the cooling system flushed and have them install it, Good maintnence and unless you have a flushing machine you can't do it correctly. But that's what i would do.
Old Oct 21, 2007 | 08:08 PM
cbrenn71's Avatar
you would need to remove the intake tube, and the throttle body to get to the thermostat. I just did the job a few weeks ago, and it took about 15-20 minutes to do the replacement from start to finish. Pretty easy job once you remove the throttle body.
Old Oct 24, 2007 | 01:13 AM
Thanks cbrenn71! You just saved me some cash. Took me a bit longer as I'm an amateur and never messed with the throttle body. Problem solved.
70_Camaro
Mar 7, 2012 12:42 AM
skinut
Dec 9, 2010 10:46 PM
linkz28
Sep 15, 2008 01:10 PM
mr porky
82-92 V6 Tech
Sep 15, 2007 06:27 PM
SbC89CAMARO
Nov 30, 2006 05:31 PM
