coolent loss
Old May 5, 2010 | 12:32 PM
Chevy101's Avatar
Default coolent loss
I have a 98 3.8 camaro that is leaking a small amount of antifreeze. i belive it is coming from the temp sending unit. I think i know where it is but i just want to make sure. i dont have a picture but is it off to the right of the oil pressure sensor? and how hard and expensive it it to replace?
Old May 5, 2010 | 04:32 PM
maguilar496's Avatar
is this what you mean.........
Old May 5, 2010 | 04:33 PM
photo is courtesy of "GORN"
Old May 5, 2010 | 07:48 PM
osduck5's Avatar
I thought the temp sending unit was under the throttle body next to the plastic piece in the picture above. I think you are referring to the cam position sensor down next to the oil sending unit.
Old May 7, 2010 | 03:49 PM
Chevy101's Avatar
yea i rechecked its not the temp unit. i just cant tell where it is coming from
Old May 24, 2010 | 05:53 PM
Chevy101's Avatar
I still cant find the coolant leak but it sprays it on the a/c compressor the oil filter and the oil pressure sensor that why i thought it might have been leaking near there but i dont see anything if anyone has any ideas it would be appreciated. and if anyone has gotten the p1870 code and has replaced the valve body on the transmission
Old May 25, 2010 | 09:06 AM
osduck5's Avatar
Check the coolant hoses coming from the heater core. Once the car is heated up a little, move them back and forth so see if they are broken or if the orings are leaking. Also, there is a plastic L shaped bypass hose at the bottom of the tensioner just above the oil pressure sending unit. They could have a crack in it.
Old May 25, 2010 | 06:16 PM
Chevy101's Avatar
i found out where is is coming from its from the heater hose the one that is on top i guess you could say. but its coming from the metal connector. anyone replace that? cause i cant find one anywhere
Old May 26, 2010 | 12:34 PM
96 3.8L Texas's Avatar
Had a shop replace that on my 96 3.8 a couple of years ago. It was one part all manifolded together at about $150. They had trouble finding it too. I'm not sure, but maybe there's another fix w/o replacing the whole thing.
Old May 26, 2010 | 03:33 PM
osduck5's Avatar
Twist the white plastic piece on the hose and pull up at the same time. The hose should come out. There is an Oring on the hose. Take that to NAPA and get them to give you a new one that is as close as you can get. It should seal the leak, unless you actually have a fractured metal peice.
