coolant spewing out. 95 camaro
hello everyone,
i've got a bit of an issue, i just replaced a bunch of stuff. tranny, clutch plate, pressure plate, slave cylinder and master cylinder. finally got the air out of that and is shifting normally again. now i filled antifreeze and i believe that there is air locks in the system because it spews out violently every couple minutes forcing me to replace it with more antifreeze... which isnt very cheap lol. any tips or hints on how to tell if there really is air in the system or if its just the thermostat opening and closing? any help would be wonderful.
thank you so much
thank you so much
park it on the steepest hill you can find, park with the front on the up side. let cool, fill radiator start car for a half a min or so and shut it off. refill. drive around the block and do it again untill it stays full.
