Coolant leak.... Again
Old Apr 2, 2011 | 08:48 AM
mrfreez's Avatar
When the timing cover leaks it won't affect your oil necessarily which is a good thing. The inside gasket is still holding, but it's leaking outside. Once you have the water pump off, it's another 8 10mm bolts you have to take out of the timing cover. Take the bolts out from the crankshaft pulley. (An impact gun makes like alot easier, and I mean alot!) You'll then need a pulley puller to remove the crankshaft pulley.You'll need a prybar to loosen the timing cover. Start at the top. Once the timing cover is off, remove all the old gasket and clean up the inside of the timing cover well. I used the black gasket maker and went around the whole seal. When you have it all together, leave it overnight before putting coolant back in the engine and let it set properly.
Old Apr 2, 2011 | 07:41 PM
Dana's Avatar
All I have to say is "bless your heart!" Mine still isn't running lol
derrickdiggler
Nov 15, 2011 09:09 PM
mccoyj91
Mar 10, 2010 08:35 PM
VTXed
Nov 25, 2006 12:04 AM
terelk
May 31, 2006 04:18 PM
akohnz
May 22, 2006 06:58 PM
