Convertible affecting speed
Old Feb 25, 2007 | 10:29 PM
96CamaroKid's Avatar
Default Convertible affecting speed
Ok so I was debating with a friend the other day. He said that convertibles, t-tops, and targa tops wont be as quick as a hard top. And seeing that I have t-tops I wanted to find out if this was true. Will my time be affected by that?
Old Feb 25, 2007 | 10:57 PM
bluovlh8er's Avatar
Default RE: Convertible affecting speed
leave them in when racing maybe?
Old Feb 26, 2007 | 12:00 AM
bill12690's Avatar
I don't see why with T tops.. wind resistance is the same, and the weight difference couldn't be much. Convertible.. the wind resistance and weight might be different.. but I'm not sure.
Old Feb 26, 2007 | 10:16 AM
JaySan's Avatar
yes it is true. If you race have your T-tops on. Because the will will catch and from the top and push against your hatch back . Plus its not good airflow it will slow you down when you race. Not by much though
Old Feb 27, 2007 | 09:52 PM
01 Camaro Cp's Avatar
Weight wise you're talking of only a couple pounds difference between the T-top and hard top. The couple of square feet of glass weighs more then sheetmetal.
The rag top on the other hand weighs at least 500 lbs more. Besides the hardware for the top, you have extra bracing to make up for the loss of stiffness from removing the top.
Old Feb 28, 2007 | 10:18 AM
usarmyrangrs's Avatar
Well said, friend. A convertible will always be slower than a hard top coupe. The windshield posts alone are extra heavy duty to substitue the mass lost in the hardtop structure. T-tops, however, I'm not so sure. I'd sacrafice a few MPHs for the sharp looks of a t-top.
Old Feb 28, 2007 | 06:17 PM
GreatWhite00's Avatar
You won't even be able to notice the difference. It's so minimal.
rext
67-69 V8 Tech
Sep 23, 2011 11:49 AM
