Codes pulled
Old Jan 17, 2011 | 11:18 PM
bowtieguy92's Avatar
Default Codes pulled
I stopped by autozone today to get my codes pulled because my service engine soon light came on. P0441 is what came up, Evaporation emission system small leak/no low condition. the probable causes are; defective or loose fuel cap (not the cause), EVAP sensor or hose cracked not connected, purge or vent selenoid defective, vacuum leak at engine.
How hard/expensive are these problems to fix?
i hope this makes sense to someone, cuz it doesn't to me
Old Jan 18, 2011 | 11:21 AM
Massey's Avatar
This is for the LT1 engine but the proceedures are very close to your car.
https://camaroforums.com/forum/lt1-lt4-tech-9/testing-evap-system-51219/
Happy reading.
Massey
Old Jan 18, 2011 | 09:14 PM
mrfreez's Avatar
Check the filler neck of the tank. If there's any holes it will have a leak. Also, if the lip of the neck where the gas cap goes onto is rusted it won't make a seal. Use some 400 grit sandpaper and sand off the rust on the filler neck to make it smooth.
grabbem88
Mar 5, 2012 04:29 PM
gofastturnleft70
Jan 3, 2012 04:21 PM
MassholeLT1
Apr 9, 2008 11:19 AM
