clutch bleeding how?
i ha ve a99 6 cyl mn5 ,the clutch pedal stays depressed at times and has to be pulled up with the foot.is this the slave cyl or master cyl.causing this and do you bleed it from the hex nut on top of line going to the bellhousing?
