Clutch
Old Jan 21, 2009 | 12:04 PM
crown7's Avatar
Default Clutch
I have a 97 RS Camaro V6 and my clutch has gone out. I can put the car in gear when it is shut off. When i start it, it will engage and let the car go. I can get all gears when the car is rolling but if i stop then i have to shut the car off again to get the car back into gear and start rolling. There is no resistance in the clutch pedal it goes up and down very loose. I have changed the master cylinder already. Any and all recomendations will be appreciated. Thanks in advance.
Old Jan 21, 2009 | 12:22 PM
SpecterGT260's Avatar
Ninja Administrator
did you check the slave cyl?
Old Jan 21, 2009 | 12:54 PM
crown7's Avatar
Default slave cylinder
I visually inspected it and made sure it wasn't loose. I could turn it, but it seemed o.k.. How would one go about checking it? The Hayne's manual say to drop trans. I'm trying to avoid that if at all possible.
Old Jan 21, 2009 | 12:59 PM
Ninja Administrator
well, it sounds like something is wrong with your hydraulics. similar thing happened to me this fall.
Old Jan 21, 2009 | 01:02 PM
crown7's Avatar
what did you do?
Old Jan 21, 2009 | 01:04 PM
Ninja Administrator
bought a new master and slave and clutch and flywheel and sent it to a shop lol. i was outpowering the stock clutch anyways so I kinda had to go that route
Old Jan 21, 2009 | 01:07 PM
crown7's Avatar
how much did it cost for parts?
Old Jan 21, 2009 | 01:21 PM
Ninja Administrator
gotta remember I did performance, but I spent 1100 on that stuff before labor. that was a spec 3+ clutch and steel flywheel
Ninja Administrator
and the hydraulic stuff
Old Jan 21, 2009 | 01:58 PM
crown7's Avatar
Thanks for the help.
