cluster f*ck?
Old Sep 13, 2006 | 09:41 PM
American_psyco's Avatar
Default cluster f*ck?
will a instrument cluster fit from a 1996 z28 in to my 1996 rs?
Old Sep 13, 2006 | 10:23 PM
Default RE: cluster f*ck?
It will fit, but I don't know how well the gauges are going to work.
Old Sep 14, 2006 | 12:55 AM
AlfredB18's Avatar
The cluster will work fine, at least for the gauges....
If you are going from a 115 to 150 MPH speedometer, I think the speed limiter will keep you from getting past 115ish anyway. You could solve that by getting the Z-rated tires (covering my toosh here...) and getting that limiter burned out with a tune job or chip, if a chip applies here.
The tach will be off. You can solve that with a tach interface from Dakota Digital for about $80. Maybe there is a way to tweak the tach, but since I don't have any kind of factory (Helms) manual to check against, I can't comment in that regard.
Old Sep 14, 2006 | 06:49 PM
wow, thanks for the heads up
Lostboy2153
May 2, 2012 10:37 AM
luciora
Apr 23, 2010 04:21 PM
BigRegUK
Sep 14, 2009 03:44 PM
waffles
Sep 11, 2009 07:52 PM
cbr600rx7
Mar 25, 2009 08:54 PM
