Chevy Tune Up!
Chevy Tune Up!
I have a 1995 3.4 V6 with 164,XXX and I think its in need of a tune up.
What should I do?
-Oil Change
-Fuel Filter?
-Air Filter Clean (K&N)
-Plugs and Wires?
I just kinda have a hard time getting it started on cold and damp mornings and I was hoping this would help
What should I do?
-Oil Change
-Fuel Filter?
-Plugs and Wires?
Check O2 sensors mass air flow sensors intake tube fluids cracks on gas cap seal, fuel filter, fuel injector cleaner, tensioner brakes rotors.... Haha I like to be thorough
Yes, all of the above. If you have had the car a while, and have not done any maintenance work, then I would start with the filters (oil, air, fuel) and change the spark plugs and wires. If it is still doing it then you might want to bring it in to your local mechanic for a diagnostic and then fix it yourself if you can. Just my 2 cents worth.
tedandangie
07-09-2008 12:06 AM
