Cat Removed by Former Owner
Old Nov 16, 2011 | 09:28 AM
chewmaize's Avatar
Default Cat Removed by Former Owner
Hi all. I'm new here and new to Camaro's. I just picked up a 98 V6. Noticed the dummy light was on and pulled her into the local shop. The Cat has been professionally removed and replaced with a straight pipe (welded). She's still running the stock muffler though. Suggestions on what to do would be great. Thanks for the help and time.
Old Nov 16, 2011 | 03:26 PM
JGuy07's Avatar
If you don't need the CAT for emissions reasons then don't worry. What was the ses light for?
Old Nov 16, 2011 | 04:02 PM
The SES is on because the cat is missing and the downstream O2 sensors see that as a failed cat. You need to replace the downstream O2's with simulators, or have the PCm tuned to delete them.
Old Nov 16, 2011 | 07:54 PM
chewmaize's Avatar
Very cool guys. Thanks for the help. I'm a Harley mechanic, never have been a car guy.....guess I have to learn a little later in life. I wasn't sure about the dummy sensors on cars, I've installed a ton on bikes.
Old Nov 17, 2011 | 10:29 AM
Just don't use the dummy sensors in place of the upstream sensors, otherwise the engine will run poorly.
vela21975
Oct 25, 2013 03:09 PM
mloaks
Apr 11, 2013 04:40 PM
Steve y87
Mar 21, 2012 12:16 PM
TheGrimReaper73
Dec 19, 2008 08:35 PM
ph0enix
Jan 13, 2008 07:22 PM
