Car's throwing codes..
Old 02-23-2009, 02:50 PM
SilverBullet5's Avatar
Default Car's throwing codes..
Hey, my camaro started throwing some codes and since I don't know how to decipher them, I figured I'd let you guys take a whack at it...
PO306
PO420
One is an o2 sensor I'm assuming, could be wrong, and the other could be a misfire perhaps?
Which would then solve the problem of a rough idle I have been having??
Thanks in advance guys (and gals).
Car is in sig if you need that for anything...
Old 02-23-2009, 02:54 PM
Saint_Ali's Avatar
P0420 is catalyst system efficiency below threshold, left bank
i dont have a 306 code in my book
Old 02-23-2009, 03:06 PM
Which means I need an o2 sensor for my left side exhaust pipe or what?? Sorry, don't know too much about that stuff...glad to see you're still alive Alih, even though you don't post in LTE anymore.
Old 02-23-2009, 03:49 PM
02StanGT's Avatar
It's not the left O2 sensor. 420 code just means the cat isn't perfoming well. Either the cat isn't doing it's job, or the sensors monitoring the cat are fouled. The O2 sensors that monitor the cat (as well as one of the two main O2 sensors) are designated as Bank 1 which is the driver side bank.
Old 02-23-2009, 09:45 PM
So I should take a gander at my o2 sensors on my drivers side tailpipe and cat you're sayin?
And what about the 306 code?
Old 02-23-2009, 09:50 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
306 is cylinder #6 missfiring. This could be the source of the fouled o2 sensor. Do you hear any rattling coming from the cat?
Old 02-23-2009, 10:16 PM
Yeah, it's annoying.
Old 02-23-2009, 10:26 PM
02StanGT's Avatar
Is all you are experiencing is the rough idle? Does the engine pull alright (i.e. smooth with no bogging)?
Old 02-23-2009, 10:28 PM
95Chevy's Avatar
generally when ive ran into a P0420 its been time to replace the cat. but both of the recent ones ive seen with that code came from a bad miss prior too the 420 code being thrown. so i would say figure out the cyl 6 miss and then more than likely you will need a new cat.
Old 02-23-2009, 10:39 PM
02CamaroV6's Avatar
Yeah i had the same problem about 3 months ago, i replaced numerous things, but it ended up being the cat converter so i would check that to begin with.
Quick Reply: Car's throwing codes..
