-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   car stopped, does not start. (https://camaroforums.com/forum/93-02-v6-tech-14/car-stopped-does-not-start-42599/)
xcorat Sep 4, 2009 09:38 PM
Hi, need help
it sometimes dis not start, i mess with power window controls, and then it started, i thought its a shortage somewhere, but unplugged everything, still the same. Then it stopped in the middle of the street, wouldnt start immediately, but after trying like 10 times, it started. today i stopped, went to subway, had it on ON for like 4 mins, and it wouldnt start again. Badly need help.
The alternator and the battery are new. I checked the voltage unplugging fuses one by one to see if that changes, but didnt (i was thinking that would give me a result if there's any shortages.
please help me, it tries to start, but doesnt, sounds like a half dead battery...! but its new...! where should I start looking..?
Gorn Sep 4, 2009 10:43 PM
What voltage do you have at the battery with the car off? What voltage do you have the everything off and the car running? What voltage do you have with the car running and everyting turned on?
This is just the first check to test your charging system.
xcorat Sep 5, 2009 12:06 AM
can that be the distributor?
can that be the distributor do these hav distribs? i got 12.1-12.4V when in ON pos. and 12.2V when started, when there was no problem, but didnt have the chance to check when it stopped, ill check it out now..!
xcorat Sep 5, 2009 01:14 AM
it started..!!
well, it stopped like 4hrs ago, and i left it there and walk to my work, then comeback after work, just turn the key and it started..!!! i dont kno what to say..! where should i start checking?
plz help. also, its giving me p0336, that comes only when I take sharp turns..!
xcorat Sep 5, 2009 01:15 AM
oh, ill test the valtages ion the morning..!
02StanGT Sep 5, 2009 08:34 AM
to answer your question, these have distributorless ignitions. after checking google, it looks like that code is for the crankshaft position sensor.
Toneman07 Sep 5, 2009 11:03 AM
Crankshaft position sensor would cause all the symptoms you described try changing it and see if that fixes problem
xcorat Sep 8, 2009 11:28 PM
it happened again..!
ok guyz, thanx a lot for the answers..!
It happened again, and i think i can rule-out any battery related problems. I got some readings,
Car idling - ~13.3V
Car off, key out - ~12.7V
Key ON - ~11.7V
Car off key out, when it does not start, -~12.5V. I also tried plugging in a car battery charger (half charged) that didnt work either. I kept my gas paddle pressed for abt 5mins, and then pressed breaks fully and tried and it worked (it might be totally random though)
Can transmission cause something like that? may be too much ATF? or the crankshaft position sensor? coz that doesnt usually come up unless I take a hard turn..!???
thanx guys..!
ColoradoCamaro94 Sep 9, 2009 03:53 PM
You've got the code for the Crank position sensor, and all the symptoms. Replace the crank postion sensor. No, too much ATF would not cause your starting problem.
xcorat Sep 10, 2009 01:39 AM
dang/..!
thanx..!
damn, isnt that really hard??? the mil is not on now though, and wasnt, when it was stopped....!!!! anyways, im new to these, think i cud do it myself???
is the sensor for sure or cud it be something related??? plz help thx a lot.
