Can't find Head Bolt Set 95 3.4
Old May 21, 2008 | 09:37 PM
cyclesofnothing's Avatar
Default Can't find Head Bolt Set 95 3.4
Has anyone replaced the head bolts for a 95 V6 3.4 basic camaro? I went to autozone and advance auto and have been looking on the net. Autozone sold me the Fel-Pro set but it doesn't include the special bolt (has a threaded hole on top of the bolt for bracket to attach) for the passanger side head. Instead they have a normal bolt in it's place. The other special bolt (bolt with extra length of threaded bolt on top bolt head) for the driver's side was included. Has anyone purchased the correct set anywhere? Can this only be found at dealer? Can you re-use the one old bolt with the new set (I'm pretty sure they are torque to yield)? Anyone run into similar problem? Thanks.
Old May 22, 2008 | 02:38 PM
TomS68's Avatar
Default RE: Can't find Head Bolt Set 95 3.4
Have not run into similar problems but I got my Bolt set and gaskets through www.rockauto.com. They carry a few different suppliers for bolt sets as I recall.
Thanks,
Tom
Old May 23, 2008 | 05:48 PM
Chappie99's Avatar
If all else fails and you dont wanna go to the dealer, find yourself a local engine shop. Tell him your problem and more than likly he can order you what you need.
Old May 27, 2008 | 06:26 PM
I ended up going to the dealer to get the missing bolt. $15 if anyone else runs into the same problem.
bran24420
May 15, 2011 11:52 PM
mikey0oo
May 1, 2011 08:54 PM
95Cammy
Mar 25, 2011 08:04 PM
raysean22589
Feb 21, 2010 10:22 PM
tee
Dec 31, 2004 01:17 PM
