camaro won't crank
camaro won't crank
need some help, YesterdayI went to start my 96 Camaro and it does not do nothing. All the lights and everything works, the battery is completely charged and it doesn't crank. I tryed my spare keys hopping it was the PASS key thing that mest up but the it didn't work and the security light is not on at all. What could be wrong? could it be my starter? but if it is could they just go out all of a sudden of do you notice it going out. I am going to check the wireing to make sure it is ok. other than that what can i do?
Thank you
Thank you
RE: camaro won't crank
I had the same problem today i was leaving work get In my car turn the ignition and nothing happens all lights come on battery is charged well luckily i was parked on a hill so i rolled it off and it started, i went home changed clothes and took it right to the chevydealer they will check it out for me tomorrow morning wish me luck
i got it fixed. I got a friend of my Dad to come and take a lot at it. It was an alarm relay. This guy that worked on it supposedly has worked on Camaros for 20+ years. He came over started it with a screw driver. and told me it was either a relay or a small fuse that starters have on them. he took it home and fixed it in about 30 min charged me $60, and i was going to change the starter.
