camaro v6 starting problems
I have a 94 camaro 3.4l v6. The other day i was driving and it seemed perfect. This morning when i got up to crank it, all it did was turn over. So i pulled the spark plug out to see if it was even getting spark and it wasn't. I took the ignition module and coils up to autozone to get it checked and they tested bad, but that lady had no idea what she was doing to i wanted to make sure it wasn't something else. So i checked the fuses and the ignition fuse under the hood was blown. When i put a new one in it, it fired up perfect. when i gave it gas the fuse blew and it shut off. now everytime i turn on the ignition i blow the same fuse.. and fuses get expensive after a while. Any suggestions of what it could be ??
