Camaro v6 Missing?
Old 02-16-2010 | 06:04 PM
Boosted8vfury's Avatar
I dont like my title
you could also have a stuck injector or a weak pump like i stated above check your fuel psi and let us know what you get and if its good we can go from there.
  #22
Old 02-16-2010 | 06:33 PM
osduck5's Avatar
Have you test your coil paks? It is beginning to sound like you might have one that is not providing a hot spark.
  #23
Old 02-16-2010 | 07:52 PM
josh95camaro's Avatar
I'll test the fuel PSI tomorrow and let you guys know the results. I'm glad you guys are all trying to help, this is a great forum!
  #24
Old 02-16-2010 | 07:56 PM
hahaha yea just test it and let us know man ill try and help whenever and i drive a honda lmao and a camaro.
  #25
Old 02-16-2010 | 08:06 PM
check the fuel pressure and it would be really nice to get it scanned. it could be more than one thing and u dont want to buy a bunch of expensive parts that are not needed. a scann can narrow it down. if its not a sensor then i would suspect the fuel pump.
  #26
Old 02-16-2010 | 08:09 PM
Well, I tried to get it scanned at both oreillys and auto zone and both told me it came up with an error, since my car is OBDI and its an OBDII scanner but my car has the OBDII plug? I'm not sure, but yeah, right now I need to narrow it down, cuz its going from intake gasket, crankshaft sensor, to the fuel pump.
  #27
Old 02-16-2010 | 08:58 PM
libertyforall1776's Avatar
Go buy a scanner that does OBD 1, like AutoXray EZ-Scan 6000, scan it and post your codes, or pay a shop to scan it and give your diagnostic flow charts.
  #28
Old 02-16-2010 | 09:00 PM
there u go ^^^ your car is a obd 1.5 or so called. its a obd 1 ecm and a obd2 plugin
  #29
Old 02-17-2010 | 11:51 PM
Fuel pressure is good, have spark to coils, have spark to all plugs and all plugs are good. I also reset the PCM and it still did the same thing when I turned the car back on, which leads me to think intake manifold gasket?
I'd like to hear some input!
Thanks, Josh
  #30
Old 02-18-2010 | 01:34 PM
what was your psi?i still dont see you not hearing a hissing from the manny if it has a leak.
Quick Reply: Camaro v6 Missing?
