camaro quitting, then starting after cools.
Old Oct 24, 2005 | 01:51 AM
fastbreak's Avatar
Default camaro quitting, then starting after cools.
Hi,
I am new to the forum but have found it interesting and hopefully helpful. I have a 98 v6 camaro. It has been running fine but about every couple weeks, it will not start after I turn it off then go to start it again. I have to leave it for several hours, then come back and it will start up and run fine for a while. Yesterday however, it died while it was running and when I went back to start it up, it would not start at all. One time a guy pushed the little valve on the gas rail, then squirted just a brief shot of starting fluid in the breather and it started up right after it died. Anyone who could give me some advice on this matter, I would really, really appreciate it. Thanks, Slowbreak at the present.
Old Oct 24, 2005 | 04:27 AM
mofur's Avatar
Default RE: camaro quitting, then starting after cools.
have you checked your fuel pressure?
Old Oct 24, 2005 | 06:28 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
fuel pump probly, if it wont start
Old Oct 24, 2005 | 11:26 PM
fastbreak's Avatar
I have not checked the fuel pressure but I will do that. Thanks guys. Is the fuel pump in the tank or is it external? Also, is there a fuel filter that might be giving me the problem and if so, where is that located? Sure appreciate the ideas.
Old Oct 25, 2005 | 12:43 PM
The fuel pump is inside the tank. Check the fuel pressure at the fuel rail fitting on top of the engine.
Old Oct 25, 2005 | 06:52 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
the pump and screen are internal
Camarokid212
Jan 14, 2013 06:39 PM
cdelemos92
Jul 14, 2010 07:28 PM
SS/Z28cam
Feb 17, 2010 09:23 AM
brizee
Feb 8, 2009 08:03 PM
