Camaro door
Old Oct 26, 2008 | 11:33 AM
sledhed32's Avatar
Default Camaro door
Just wondering how to level my door back out it shuts hard it is sagging. I know this is a common thing for these cars due to the long door and weight of them. Just wondering if i just need to get new door pins or how to level it back out thanks a lot.
Old Oct 26, 2008 | 02:20 PM
Default RE: Camaro door
Sagging doors=worn hinge bushings/pins.
Something like this: Hinge Pin Kit will get the door fitting like it should again. Since the door hinges are welded to the door, fixing the existing ones is the easier route to go. The original pins don't bolt on like the replacement ones though, so you'll need to grind them off.
Old Oct 26, 2008 | 07:30 PM
ledzeprokon6's Avatar
^^ what he said
Old Oct 26, 2008 | 07:58 PM
sledhed32's Avatar
Alright that helps a lot. Do you think that if I get a new door with all the hook ups, that would do the same if it shuts good on the car it is on. If you don't get that lol, I'm re-painting my car in the spring and my current door has some minor fiberglass damage and of course the sagging, but if I got a new one from the scrap yard that shut good on the car it was on and I take and put it on mine it would work too. Sorry for this being so long. But thanks a lot for the help Camaro69 you've gave a lot of good tips to me thanks a lot.
side-winder
Feb 26, 2013 02:32 AM
MaxTheKiing
Jun 17, 2010 09:02 PM
thomasstuart
Nov 29, 2009 10:36 AM
Skillet89
May 4, 2009 12:12 PM
lawmanadam
Oct 5, 2008 08:32 PM
