camaro with 201,000 miles
Old Dec 22, 2008 | 02:41 AM
shippy8907's Avatar
Default camaro with 201,000 miles
I just bought the car a few days ago. What would you recommend that I do maintenance-wise to the car? I have already got plugs and wires for it. I changed the oil and filter and air filter yesterday and I'm getting ready to put a fuel filter on it. is there anything else that I am missing that I should probably change?
Old Dec 22, 2008 | 03:20 AM
cbr600rx7's Avatar
Default RE: camaro with 201,000 miles
First off what year and engine are we talking about
Old Dec 22, 2008 | 01:24 PM
shippy8907's Avatar
95 with the 3.4
Old Dec 22, 2008 | 02:46 PM
bryans3.4 95's Avatar
get some carb cleaner and spray the intake. check the transmission and rear differential fluid. i did this when i got mine 2 months ago. 190,000 mi 3.4l
Old Dec 22, 2008 | 07:19 PM
shippy8907's Avatar
I found out that I have a weak motor mount. the engine is sagging down on the passenger side. and i need new tie rod ends. would the mount cause the car to shake pretty noticeably? I have changed what I have mentioned above but it still seems to be sluggish.
Old Dec 23, 2008 | 02:55 PM
yeah my mazda 3 had a fubar mount and it was shaky as hell. you definitely need that replaced.
Old Dec 24, 2008 | 12:17 AM
typeomang's Avatar
the motor mount and bad tie rods can cause this.......SFC
Old Dec 24, 2008 | 08:27 AM
isaac11's Avatar
my motor mounts were lose in my dodge and it shook like crazy
Old Dec 24, 2008 | 09:59 PM
sledhed32's Avatar
New shocks and struts , if it leans to passender side, like most maro's. Not too expensive and somewhat easy if you know what your doing.
x01660
Dec 12, 2009 12:48 PM
amanda_x21
Dec 6, 2008 02:53 PM
markbach
Sep 15, 2007 08:18 AM
