a cam
http://www.intense-racing.com/Mercha...egory_Code=HCVwork in my 97 3.8 what say you other kings of V6
Yep, I plan on getting a comp ARH sometime...
Forgive me if I forgot, but you dont have all the bolt ons yet right? If not, definetly get those first
While your doing a cam you might want stronger pushrods, lifters, etc and a good tune
It's up to you...
you could put a cam in there as is, but if it was me (this is what I'm going to do)...complete your exhaust (headers, cat, s-pipe), 1-piece aluminum LS1 driveshaft...
you'll need the cam install kit, and I would get some comp pushrods...however if your tearing apart everything, then I would do all you could while your in there, ported heads and intake if you have the money, lifters, etc and then you'll want tuning software or a mail-in tune
esh lol, well i knew id need the install kit since my exagust is a cat back system dosent it include the cat and s pipe and will headers make that much of a diferance with a cat back system already installed beyond sound i mean as far as the drive shaft ..... you got me there havent even looked into that
Your exhaust is restricted by it's weakest point, go complete for the best results obviously
Sure the cat-back will help a little, but it's still getting restricted at the manifolds, stock cat, 2.25" spipe etc
Driveshafts are like $125, check out ebay or ls1tech classifieds, very easy to do
the driveshaft will not fall out when you take the cam out...
the driveshaft is the long shaft that goes from the end of the tranny to the rear end, simply undo 4 bolts, the mid-section harness, and it should slide out of the tranny, very easy job to swap in an aluminum driveshaft.
As for cam, you will need to tear apart the engine a little, I'd wait until you get a little more comfortable and do some more research about the subject
