A/C Question
Old Mar 18, 2010 | 03:12 PM
Racer's Avatar
Default A/C Question
The compressor in my 95 3.4 went bad and does not hold a charge. Def. leaking from the compressor.
I have a new compressor and drier ready to install. The compressor is dry and it says to dump the oil from the old compressor into a container and put that much oil into the new compressor. Well how do you know if the correct amount of oil was in the old compressor? Is there a certain minimum amount there should be? 4oz etc? I know not enough is bad, but too much isn't good either as it would affect the cooling.
Also, if I pull the system into a vacuum, will that drain all the oil I just put into the compressor?
Its been quite awhile since I did A/C work and can't quite remember.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
