a/c help
Old 05-04-2008, 07:37 PM
hevymetalg's Avatar
Default a/c help
my a/c wont kick on, anybody know how to hot wire it to get some of that refrigernt (cant spell) crap in there so i can find the leak?
Old 05-05-2008, 04:59 PM
02StanGT's Avatar
Default RE: a/c help
You don't need the compressor running to put refrigerant in there. They have refill kits that should have everything you need.
Old 05-07-2008, 12:56 PM
hevymetalg's Avatar
did that, it still wont kick on.
Old 05-07-2008, 04:51 PM
02StanGT's Avatar
There is a pressure switch in the line. Take the plug off, andput a jumper inthe plug. If the compressor kicks on, get a new sensor. The sensor is there to keep the compressor from running without enough refrigerant, so it doesn't burn itself up.
Old 05-07-2008, 05:02 PM
LT1RUNNER's Avatar
Does that include the V8's too.
Old 05-07-2008, 05:03 PM
02StanGT's Avatar
Yes it should.
Old 05-07-2008, 05:08 PM
LT1RUNNER's Avatar
Same fricken issue and here in Arizona it gets !@#$ hot! AC is a must.
Old 05-07-2008, 06:40 PM
hevymetalg's Avatar
ORIGINAL: 02StanGT
did any one try this? i did and mine didnt kick on?
Old 05-08-2008, 07:56 PM
02StanGT's Avatar
There is a way to jumper it, obviously I told you the wrong way. I tried on mine earlier and couldn't figure it out. Though, if you have enough refrigerant in there, either A) that switch is messed up, or B) the A/C clutch is messed up.
Old 05-09-2008, 03:57 PM
hevymetalg's Avatar
ORIGINAL: 02StanGT
so....whats the other way to jump it then?
