Burnout Question
Old May 21, 2007 | 07:50 AM
DKap22's Avatar
Default Burnout Question
Yesterday i was doing a burnout and i realized when i got out that both of my tires were in fact spinning. can anyone explain to me what happened? like i thought v6s werent posi's
but anyways i have a video and ill post it soon.
Old May 21, 2007 | 08:57 AM
countryboy's Avatar
Default RE: Burnout Question
You prolly have the Y87 package on your car. What year is it? Badinfluence can help you with that.
Old May 21, 2007 | 10:15 AM
DKap22's Avatar
its a 2000 V6 5 Spd. how can i tell if i have that i dont have a the body kit or anything so if someone could tell me how i can determine that that would be great thanks
Dave
Old May 21, 2007 | 12:32 PM
buddywackos's Avatar
i don't think they have anything different on the body, i think they just have a posi rear end and the z28 steering and suspension. i'm not too sure though.
Old May 21, 2007 | 01:21 PM
2lucke4u's Avatar
Look at the codes on the door for the y87.
Old May 21, 2007 | 02:31 PM
Pull the cover off the rear end and take a look. Probably needs a lube change anyway.
Old May 21, 2007 | 04:26 PM
badinfluenceRS's Avatar
Y87 perf code
G80 i believe is the LSD code
Sometimes both wheels will spin a little, if you do a brake stand for several seconds, both wheels keep spinning and spinning
Old May 21, 2007 | 05:06 PM
DKap22's Avatar
Where do i look for the Y87 code and wat is the G80??
and from the moment i start to the second i finish they are both spinning if that means anything
Old May 21, 2007 | 05:23 PM
usarmyrangrs's Avatar
Look at the placard on the driver's door. There will be a list of 3 digit codes.
BoricuaHec01
LS Series Tech
Feb 28, 2011 04:21 PM
