Bad trend...
Old Jul 26, 2008 | 02:34 PM
evilkal's Avatar
Default Bad trend...
Well my motor ate the dust and I think my transmission is in the process. I know a lot about an engine but not much about my transmission or driveline... I know how they work, but I don't know what would cause problems in one and how to diagnose certain parts...
So I'm here to ask you guys... I will back up, and when I shift back into overdrive, sometimes, I'm stuck taking off in 3rd gear unless I shift up to myself in the auto. Even then, the only two gears that work when this happens are 2nd and 3rd. It will not shift into 4th at all, so no overdrive... And 1st doesn't work either. It seems to work after I turn the car off for a period of time and mess with the shifter for a minute. Any of you guys know whats going on here and am I gonna be throwing around another $1000 to keep my car in good shape?
Old Jul 26, 2008 | 05:49 PM
bidicamaro's Avatar
Default RE: Bad trend...
Have you checked your fluid level? I've seen a handfull of transmissions do a similar thing when low on fluid. Also, how's your shift linkage? If it's binding it may only be letting you in those gears.
Old Jul 26, 2008 | 07:07 PM
evilkal's Avatar
Just got done servicing the transmission. Filter and fluid both.I'll check the linkage out too btw. Ty
Old Jul 26, 2008 | 07:23 PM
importmd's Avatar
3 honks and I'm on the floor... In reverse! Well I get up around 4 grand and cut my wheels left and pull my E brake for a split second and slam it into drive. 180 in the middle of the road (I was in front of him in reverse too lol). When I get turned around I slam it
maybe its because how you drive?
Old Jul 26, 2008 | 07:27 PM
98RCMARO's Avatar
ORIGINAL: importmd
Why don't you try and help instead of being an *******?
He asked how to fix it, yes he plays hard, he didn't ask how it happened, just how to fix it.
Old Jul 26, 2008 | 07:43 PM
importmd's Avatar
could be plugged valve body or a solenoid problems...happy little boy?
Old Jul 26, 2008 | 07:44 PM
importmd's Avatar
or he just blew it up from beating on it
Old Jul 26, 2008 | 08:54 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
kal were cool and all bro but im sorry i have too.................probly from doing sooooo many J turns hahahaha[sm=sorry.gif]
Old Jul 26, 2008 | 09:15 PM
Fortee's Avatar
HAHAHAHA thats pretty good Nic, lol
Old Jul 26, 2008 | 09:19 PM
MusicMan's Avatar
The Jazz Man
I'm too old school for this, I was going to say something about a vacuum modulator, but these trannys are shifted by the computer right? It might just be going sour on ya Kal. Maybe add some of that slick 50 auto trans additive to it? I just don't know squat about new trannys. Gimme a Turbo 400, and I'm there
