ASR v.s. SGS
Old Jul 12, 2008 | 10:08 AM
JaySan's Avatar
Default ASR v.s. SGS
So what is better the ASR or the SGS on camaro's ??? Can some one explain pros and cons???
Old Jul 12, 2008 | 10:22 AM
BigNic's Avatar
4' 11" 117 lbs of fury!
Default RE: ASR v.s. SGS
asr is traction control when it feels the rear wheels slipping it robs power from then till you are griping better agian. SGS is second gear start which just makes it so when you sit at idle your in second gear thus you bog off a start keeping it more under control in wet conditions.
