Adjusting Camaro Sonar Headlights
Hey guys, I got them sonar headlights and they are hard to move up, they point down a little too much.
I see a phillips screw on the outer side for each, but turning it doesnt seem to do anything.
There is also a 4mm tip I can turn in the center which doesnt seem to do anything either. Atleast not that I can tell.
These are the ones I got:
Also the light isnt that bright in the projector thing, perhaps If i could move them up I could see better... But, is there a better bulb to plug in thats legal that gets better light?
With my headlights I use the Silverstar Ultra 9006 and 9005 bulbs. They are nice and bright white. I found that when I was installing my lights that the adjustment screw did not want to go into the provided hole that is was supposed to go into which made it impossable to adjust properly. Once I popped the adjustment screw through that hole in the headlight bracket they adjusted just fine.
Massey
Massey
Thanks dude Ill check that out.
Those ultra stars look cool, but it looks like they are only for the brights, I cant tell. The one with the hook it for the bright? And the straight one is the regular light?
Do they last you long?
Get HIDs for low beams, that's what the projectors are for...
http://ddmtuning.com has them, and what I use...
AmericanMuscle1989
03-03-2013 06:56 PM
