99 Flooding in Cold Weather
Old Jan 24, 2013 | 01:43 PM
RedSled99's Avatar
Default 99 Flooding in Cold Weather
I live in Iowa and it has been a little cold lately. This morning I started up the Cam and drove down to the gas station. Shut it off and filled it up. Went to start it and it would crank and fire but not start running. I could smell a fuel build up. So I let it sit and tired again. In doing so I drained the battery. After getting some one to jump me I put the pedal to the floor and it fired right of. This is the second time in a couple months that it has happened. Has anyone else had this issue? I did not let it warm up before I left.
Edit: It's a 3.8L
Old Jan 24, 2013 | 03:58 PM
have it scanned for trouble codes at your local parts store if they can. test temp sensors, check air filter, fuel filter, test fuel pressure, check spark quality with a spark checker. how old are the plugs?
Old Jan 24, 2013 | 09:30 PM
RedSled99's Avatar
I have had the codes read. It was throwing an O2 sensor code but went away. I have never replaced the plugs and i have owned it a rear. I will check those and have it hooked up again.
B_Dubya
Oct 21, 2014 04:06 PM
Jxp
Jun 6, 2014 09:40 PM
husker_camaro95
Feb 16, 2011 07:41 AM
robmnrd
Jan 6, 2008 04:08 PM
danisdad
Dec 21, 2005 10:51 PM
