95 running rough
Old 09-02-2010 | 09:37 PM
osduck5's Avatar
Still need to get at least a compression test done. If valve stem seals are bad, oil will run down around the seal into the cylinder. If the rings are bad, the oil will get pass the rings into the cylinder.
Old 09-02-2010 | 09:38 PM
kc9nvw's Avatar
Originally Posted by Chaotic94
My grandfather in law has been a mechanic for 30+ years and he has built many car from the ground up. He said it sounds like a bad valve... He said there's no way to tell for sure without a compression test.
Ill get a compression test done on it. Maybe get lucky.. thanks
Old 09-02-2010 | 09:39 PM
kc9nvw's Avatar
Never seen unburnt oil coming from exaust..thats a new one for me lol
Old 09-03-2010 | 08:37 PM
kc9nvw's Avatar
Just a follow up.. I pulled the plugs and I have oil on the driver side back plug.. figure its rings bad. From what I can tell a replacement engine maybe in order. thanks for everyones responses.
Old 09-05-2010 | 08:00 PM
kc9nvw's Avatar
So I removed all the spark plugs and all of them were black. the driver side back had large amount of oil and the passenger side front also. But like i said all of them are black. Im thinking must be worn valve seals. i cant imagine every piston ring is bad and there is not any metal or enything in the oil pan.
Old 09-07-2010 | 10:10 PM
mrfreez's Avatar
Yup, definately sounds like valves. One of the reasons I'm rebuilding an engine over the winter. These engines don't seem to last too long from factory and wear out quickly.
Old 09-08-2010 | 08:14 PM
kc9nvw's Avatar
Checked compression 120psi or close to it on all cylinders . Will probably go ahead with new valve seals this weekend. Haynes manual has step by step instructions .... Looks like a good weekend project for me lol
Thank you to everyone for helping me with your opinions
Old 09-08-2010 | 11:46 PM
shaun91's Avatar
hey, nice results on the comp check, it does sound a lot like valve train with what your saying, one thing that caught my attention was the oil on your hand from the exhaust, is you get the engine problem fixed get that cat checked also, may be bad, my cat is toast after coolant when everywhere in the engine cuz of a lower intake manifold gasket blowing, it happened to go through the exhaust as well
Old 09-09-2010 | 04:01 PM
kc9nvw's Avatar
Yah, the person that had it before me removed the cat. I would suppose they thought it was bad. Mayb they thought that was problem with car at one time
I ll probably put the cat back on after valve seals are fixed lol
Skull's67
04-23-2014 07:48 PM
Socom
67-69 V8 Tech
01-24-2013 01:34 AM
csmiddy
67-69 V8 Tech
12-09-2012 10:12 PM
BasicConcepts
05-08-2010 01:51 AM
Djonemore
04-07-2009 10:49 PM
Quick Reply: 95 running rough
