95 camaro tranmission help
yeah i just replaced my transmission in my 95 with a transmission out of a 98 and i got everything hooked up and running right but when i went to drive it my speedometer was really off it says i am going 50 when i am barley moving any ideas on what i can do to fix this
thanks |
Sounds like the wrong size speedo gear, If i was to guess
well i had to cut the wires to the 95 speed sensor and wire it up to to 98 speed sensor but had no choice
the tail shaft housing cant be switched? check here, see if they have something. http://www.transmissioncenter.net/sp...n_______va.htm
