95 camaro no fuel to the injectors
Old Apr 15, 2022 | 04:58 AM
trionsolar's Avatar
Default 95 camaro no fuel to the injectors
i put a new fuel pump and new gas tank it runs if i put gas in the intake fuel it working i am thanking it a ground some were i fix the ones by the battery
Old Apr 15, 2022 | 12:12 PM
You should start a new thread instead of using a 10 year old one.
It very well could be a ground and it never hurts to clean grounds but you should run some tests first. First a fuel pressure test to verify the pump install went well and that the pump is not defective. You should be able to borrow a fuel pressure tester at most chain type parts store. You can also buy them cheap at Harbor Freight and resale it once you are done.
Assuming that is ok then you can us a high quality electronic rated multi/volt meter to check for power at the injector. You should have 12 volts with the car sitting and the key on. Next you should use a noid light to test to see if the computer is grounding the injector. If you are missing the 12 volts or the pulsing ground would determine your next step. You can find noid light pretty cheap at most parts store, they are manufacturer specific and ca vary form year to year, I have not bought one in a long time.
You could have an issue of no power to the injectors, wiring or relay. It could be PCM or ground or the security system telling the Computer not to fire the injector. PCM issues should give you a code, wiring issue may not.
Carpenter108168
Apr 15, 2021 05:28 PM
ChevyCamaroRS91
Jan 4, 2018 11:22 AM
Brady Mikesell
Aug 23, 2013 07:42 AM
JerseyBoy9696
Feb 2, 2008 01:14 PM
inches1118
Feb 17, 2006 02:09 PM
